I need a .map file!!!! - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 7 (permalink) Old 09-13-2004, 01:10 PM Thread Starter
Cool I need a .map file!!!!
Does anyone know where I can get a .map file for my power commander that is set up for a Yoshimura bolt on exhaust, TRE switch, and PAIR valve removed? I have looked on the Yoshimura site and nothing there. Obviously if I don't have to take it to a shop it would be best.
Y2K750 is offline
post #2 of 7 (permalink) Old 09-13-2004, 01:19 PM
Welcome to 2Wheel Forum. The shop I take my bike to told me that they go online and download it from there. I think he said he gets it from DynoJet. Have you tried there?
GSXR1000DJ is offline
post #3 of 7 (permalink) Old 09-13-2004, 01:25 PM
You say you obviously don't want to take it to a shop but as siad previously here in many other threads. You are always best to take it to a shop. It is a common known thing that no 2 bikes are the same. Even if it is the same year and same bike, off the same manufacture line. They just aren't always the same.
If you take it to a shop with a dyno, they can give you a custom map for your ride that will give you the most for your money you have into that bikes mods....
Just my and many others
post #4 of 7 (permalink) Old 09-13-2004, 11:49 PM
What he said...
post #5 of 7 (permalink) Old 09-14-2004, 06:42 AM
Although, if I had one I'd hook you up.
post #6 of 7 (permalink) Old 09-14-2004, 06:44 AM
kinda of pricey to get customs maps
it could be on the dyno for a while
beanz is offline
post #7 of 7 (permalink) Old 09-14-2004, 09:29 AM
if you're going to do it, might as well do it right
Need4Speed is offline
