Bike's First Service - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 28 (permalink) Old 11-27-2005, 10:38 PM Thread Starter
My ZZR600 is due for its first service. What is normally included in the first service? Do the valves need adjusted? I can do things like oil changes but I'd rather leave the other stuff to a bike shop.
ZZRider is offline
post #2 of 28 (permalink) Old 11-27-2005, 11:16 PM
The first question is, how much do you really know about bikes.
First service is mostly oil change. They also check allot of other stuff when they do it. Mostly visual checks of fluids, breaks, loss or missing bolt, chain and listen for ticks, knocks etc.. It is also documented for any later warranty issues.
post #3 of 28 (permalink) Old 11-28-2005, 02:52 AM
Just change the oil yourself and skip the service from the dealer.
The first service is a joke. I'm sure most dealerships say they check this and that but you just know they haven't done ****.
Read your manual for the maintenance schedule.
beanz is offline
post #4 of 28 (permalink) Old 11-28-2005, 07:46 AM
The first service is mainly a $ 135.00 oil change and look over. It is documented, as said above, for warranty information.
post #5 of 28 (permalink) Old 11-28-2005, 08:49 AM
jtemple's Avatar
My dealer told me that my warranty would be fine if I did all the work myself, as long as I documented everything. So, I followed the owner's manual and called it good.
I ended up saving myself about $120 doing it, felt better about the work that was done and started learning something about bikes.
The dealer hasn't touched my bike since it left the showroom floor. Granted, it hasn't been that long since it has left the showroom floor. But, my intention is to do all of the work myself.
2006 Kawasaki ZX-10R
jtemple is offline
post #6 of 28 (permalink) Old 11-28-2005, 09:07 AM Thread Starter
The dealer said they would do the 1st service for $40 +fluids. I wasn't sure if that was a good deal or not. I think I'll just do it myself.
ZZRider is offline
post #7 of 28 (permalink) Old 11-28-2005, 09:53 AM
Ya I know that on my 9R I skipped those... I don't think I did any of those services at the dealer. I don't think they are going to check anything that you couldn't do.
Now on something like the chopper, there is a big list of things that they check... however, they give me the first dealer service for free so...no biggie... but that's a very different bike and different service.
post #8 of 28 (permalink) Old 11-28-2005, 12:45 PM
For the record.
The only time the dealers see my bikes are for the major services. I also keep all receipts for oil, filter and other parts just incase I have a warranty issue.
post #9 of 28 (permalink) Old 11-30-2005, 03:10 PM Thread Starter
Okay, another question. Should I use Kawachem or do you guys suggest another oil? What brand oil filter should I use?
ZZRider is offline
post #10 of 28 (permalink) Old 11-30-2005, 06:35 PM
jtemple's Avatar
I use Castrol Syntec. Don't switch to synthetic until you're fully broken in, though. I waited until 2000 miles.
jtemple is offline
post #11 of 28 (permalink) Old 11-30-2005, 08:45 PM
with mine, it had 14k on it. I switched to synthetic regardless if taht was in the bike or not. I used a mobil 1 oil. My buddy uses some fancy oil that he swears by, but I cant remember the name of it. I will let you know if I find out
snadamo is offline
post #12 of 28 (permalink) Old 11-30-2005, 10:08 PM Thread Starter
What brand oil filter?
ZZRider is offline
post #13 of 28 (permalink) Old 11-30-2005, 10:37 PM
Just keep it simple and get the OEM filter.
post #14 of 28 (permalink) Old 11-30-2005, 11:39 PM Thread Starter
So do I need to switch to synthetic now or should I wait a while?
ZZRider is offline
post #15 of 28 (permalink) Old 11-30-2005, 11:43 PM
This has been discussed many time here. Do a search of our threads.
I use conventional oil the first time. Then a synthetic blend. Then full synthetic.
post #16 of 28 (permalink) Old 11-30-2005, 11:45 PM
Click here for a link to a recent thread.
post #17 of 28 (permalink) Old 12-01-2005, 11:41 AM
I have used both the Kaw oil and filters and they're fine. I then would switch to a syth oil of your choice and a K&N Gold Performence oil filter. Or even better buy the Scott's Oil filter.
post #18 of 28 (permalink) Old 12-01-2005, 01:01 PM Thread Starter
Can I just use Mobil1 20W-50 from Autozone or does it have to be an oil for motorcycles? Yeah, I know, I sound like an idiot but, I'm still a newb.
ZZRider is offline
post #19 of 28 (permalink) Old 12-01-2005, 01:12 PM
Check your owners manual for oil requirements. I'm pretty sure Mobil will meat and or exceed them.
edit:
I just checked and Mobil 1 is GS-4.
It would be fine for your bike.
post #20 of 28 (permalink) Old 12-01-2005, 01:33 PM
This has been another debate on TWF!
You DO NOT want to use car oil in your MC! It is not meant to be in there. First off your MC sees alot more abuse and usually runs alot hotter than your car. Second and most important the car oil isn't tested or meant to run with your wet clutch!
