Might be screwed. What would happen if.... - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 10 (permalink) Old 01-04-2006, 10:03 AM Thread Starter
Sime's Avatar
Ok guys...may be a major mess up on my hands here! But I sincerely hope not.
With my impending move back to Australia and the severe mismanagement by the shipping company, I didn't get to spend the time I would have liked to properly prepare my bike for the shipment by container from Detroit to Melbourne, Australia. I know that certain things have to be accomplished for winter storage, but the bike technically wasn't going to be stored for the winter. Just a trans-pacific boat trip!! Nothing major. ;p
I removed the battery and drained the gas tank. Before I did so I put a double-dose of stabil in the gas tank (that had premium fuel in there) and ran it through the carbs. I didn't drain the float bowls though. Not a problem as I left it like this last winter and the bike started fine this Spring. I am also not worried about lubricating the chain as that is going to be replaced when I fit the single sided swingarm.
I didn't drain the oil, but it was replaced with Amsoil Synthetic only about 1500-2000 miles ago. I plan to replace the oil and filter when I get to the bike when it arrives.
My problem is this....
Earlier in the year, I upgraded to a 954 radiator to my bike when I fitted the 99 bodywork. I replaced the coolant with distilled water and Redline Water Wetter. I can't seem to recall if I put just Water Wetter and distilled water in the cooling system, or if I also added about 25-50% antifreeze in there too.
Well, the night I loaded my bike, it was about 15F out. It was the same the next night. The bike has been in my garage up until the point it was loaded into the container. In any event, it was probably below freezing for quite some time. The container left my house on December 6th, and made it's way to LA where it sailed on December 23rd. So the bike was sitting in freezing weather for a while....anywhere from 2 days to about 10 days I figure. Plenty of time for stuff to freeze up. I am not sure when it left Detroit for LA.
Worst case scenario. Let's say I only have the Water Wetter and distilled water in there, with no antifreeze. Would the coolant have frozen in my bike? That being the case, do any of you think my motor would have been damaged by this (the coolant freezing inside the motor)? The bike hasn't been attempted to be started in this condition (it's just been sitting in the crate), and obviously the coolant would have thawed out again by the time it left Detroit's freezing temps.
Am I screwed? What sort of damage might I expect? Has anyone here been in this position or know of someone else who has...if so, what was the outcome? Yeah, I know I'm stupid. I feel like such an idiot. I should have replaced it with the proper antifreeze stuff or just left it drained altogether. I was in such a rush, I really wasn't thinking (what compounded things was the dismal fact that I was up for 62 hours straight while I packed/loaded the container).
Feel free to be forthright with your honesty peeps. If I wrecked my motor, I know this is my fault.
Thanks in advance for any info,
Sime
Any Aussies that want your bike painted.....give me a holler! www.paintwerks.com.au
Sime is offline
post #2 of 10 (permalink) Old 01-04-2006, 12:53 PM
Well your in luck, the handy dandy freeze plugs will pop before the engine case will. So worst comes to worst you will have to replace the frezze plugs and some seals.
post #3 of 10 (permalink) Old 01-04-2006, 02:49 PM
Taken fro the Water Wetter web site.
http://www.redlineoil.com/whitePaper/17.pdf
WATERWETTER® SUPERCOOLANT FREEZING POINT DEPRESSION Red Line waterWetter® does not significantly reduce the freezing point of water. If the vehicle will see freezing temperatures, an antifreeze must be used.
Water expands approximately 9% upon freezing which can cause severe engine damage. Even in summertime, the use of air-conditioning can blow
freezing air through the heater and cause freezing of the heater core unless approximately 20% antifreeze is used.
I wouldn't worry about it. Most times the shipping crates are stored inside and are not put in the conex until they roll out. Every time I have moved over sea's my bike and other household goods are stored inside the warehouse. This helps cut down on the chance of all your stuff getting mold on it and then the shippers having to replace your stuff. Just call the shippers and find out if your stuff was left out in the weather.
Marsolais is offline
post #4 of 10 (permalink) Old 01-04-2006, 04:41 PM
I think the bike will be ok Sime.
post #5 of 10 (permalink) Old 01-04-2006, 04:59 PM
I would not worry about it either. Usually there is enough anti freeze floating around in the raidator and the bowls of the water jackets to keep it from completly freezing. Also, I think it would take more than a few days to freeze everything over.
Monster231 is offline
post #6 of 10 (permalink) Old 01-04-2006, 05:51 PM
It's cool trust me. I once had race bike with just water in it sitting in Negitive degree weather for 3 days and it was fine...
post #7 of 10 (permalink) Old 01-04-2006, 09:59 PM
I wouldn't worry about it until you see a puddle under the bike My guess is it will survive.
post #8 of 10 (permalink) Old 01-05-2006, 12:06 AM
Yeah I think it will be ok. But I'll be interested in hearing about how it worked out for ya.
How much did they charge to move it?
Also, this is the reason to replace that water wetter with some nice engine ice. No freezing problems!!
post #9 of 10 (permalink) Old 01-05-2006, 01:01 AM Thread Starter
Sime's Avatar
Thanks guys. I sure hope so. I am kicking myself because at the time I saw the price of the engine ice, I was too stingy to spend the money. If this comes to bite me hard on the ass, my lesson has been (expensively) learned.
Will keep you all advised as soon as I find out myself.
As to shipping the bike Chris, I got a whole 20ft container for $3775 which included the wood free crate for the bike, plus I got to put all my other stuff in there too. We loaded it at my house, and that fee is to the port of Melbourne, so I do have to get a truck there to load everything into. But considering I was quoted by another company just to ship the bike including a crate at $2345, I'd say we got an excellent deal!
The company is www.discount-shipping.net if anybody needs anything moved. Apart from the container arriving late which wasn't their fault, they are good people.
Sime is offline
post #10 of 10 (permalink) Old 01-05-2006, 01:14 AM
I think you will be alright also. As twisty stated: freeze plugs will pop before the block. However the head is still at risk. Again, I think it will be fine.
