95 ZX9R Water pump problems :( - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 9 (permalink) Old 01-19-2006, 06:14 PM Thread Starter
The title explains itself.... My water pump isnt working and my engine is overheating....Theres no rad fluid going anywhere.... How do I fix it?
Aesop Ninja is offline
post #2 of 9 (permalink) Old 01-19-2006, 11:15 PM
Get a service manual and a new water pump from the dealer! Or just take it into the dealer in a pick up!
post #3 of 9 (permalink) Old 01-19-2006, 11:36 PM
Quote from the other thread! A place to get manuals...
post #4 of 9 (permalink) Old 01-20-2006, 02:50 AM
Could also be your thermosatat. I'd replace both at the same time. It can't be that much.
post #5 of 9 (permalink) Old 01-20-2006, 08:46 AM
I'd do thermostat first...when water pumps go out...there is usually evidence of water leaking around the seals
post #6 of 9 (permalink) Old 01-20-2006, 05:57 PM
post #7 of 9 (permalink) Old 01-20-2006, 10:25 PM
I guess the first question is...how did you determine the water pump is not circulating coolant?
post #8 of 9 (permalink) Old 01-21-2006, 02:24 AM
check the thermostat first.
post #9 of 9 (permalink) Old 01-24-2006, 12:12 PM
Not enough info...
Fan not working? Low coolant? ever changed the coolant? pressure cap faulty? water pumps don't just quit working. there is usually something that damages them. what's the temp and when does it overheat?
