Degreasers............ - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 17 (permalink) Old 02-12-2006, 08:10 PM Thread Starter
Anyone know and good de-greasers, my rims on my bike are all gunked up....I wanna give it a good clean and not let it build up again, same goes for my sprocket
kaboom78 is offline
post #2 of 17 (permalink) Old 02-12-2006, 08:19 PM
Simple Green. That stuff works good on wheels.
post #3 of 17 (permalink) Old 02-12-2006, 08:22 PM
first off kaboom78
a buddy of mine uses this degreaser called "SLAM" which is amazing stuff. It is a water based degreaser and really does an awesome job. He sprays on SLAM and lets it sit on there a few minutes and rinses it off with a garden hose and all dirt and grease will come right off.
Do a google or yahoo search on the stuff.
post #4 of 17 (permalink) Old 02-12-2006, 08:38 PM
kaboom78 i have used simple green an it works, although "slam" sounds like something to look into.
rider76 is offline
post #5 of 17 (permalink) Old 02-13-2006, 01:00 AM Thread Starter
thanks all much appreciated!
kaboom78 is offline
post #6 of 17 (permalink) Old 02-13-2006, 02:46 AM
No prob...stick around. What bike do you have?
post #7 of 17 (permalink) Old 02-13-2006, 08:25 AM
be very careful with degreasers...the strong ones, with butyl ethers and high Ph's don't know the difference between grease and your "O" rings...
The degreasers with metasilicates are what your white wall cleaners contain and are less likely to damage...
I have some that you can spray on, rinse off that will pull the lube and seals out with it...make sure to read the labels...
post #8 of 17 (permalink) Old 02-13-2006, 11:17 AM
First
Bee brings up a good point. Don't get the good huffin stuff. I use a Castrol Degreaser. It comes in a purple spray bottle. It works great. Just spray some on the rim and wipe off. No bad residue or streaks. Makes the wheels all shiny.
I have heard that many people use simple green. It is a great product and I use it alot...just not on my wheels.
post #9 of 17 (permalink) Old 02-13-2006, 11:30 AM
as long as they're not painted... and your carefull.. you can use Breakleen, red or green(i think) cans... I use the red... but if you do make sure you've got a fan blowing the fumes away... anywas... spray it on a rag (not directly on it... to keep from getting spray on the tires, paint, seals) and rub away... I use it whenever I'm working on my truck. removing 200,000+ miles of oil,grime,tar... works great... but like I said... don't get it on paint or rubber seals
post #10 of 17 (permalink) Old 02-13-2006, 11:31 AM
But breakleen isn't good on o-rings.
post #11 of 17 (permalink) Old 02-13-2006, 12:04 PM
Simple green. That is one mild degreaser we use it to clean our wheels. And let me tell you, after a day of track days or racing there is a ton of brake dust on the wheels and simple green gets it all off.
Laura
SpeedWerks.com is offline
post #12 of 17 (permalink) Old 02-13-2006, 06:41 PM Thread Starter
I have a 03 F4i , I just want to ride! must be nice being from Vegas.......... I would love to ride on the strip
kaboom78 is offline
post #13 of 17 (permalink) Old 02-13-2006, 07:50 PM
Dollar Store bathroom cleaner works great! Buck a can you can't go wrong. I've found that most any household cleaner and a rag do a pretty good job. Anything strong enough to eat off the gunk with no wiping is going to be bad for something else nearby the wheels. I'd try whatever you got before you spend money on "wheel" cleaner.
Bandit 6S is offline
post #14 of 17 (permalink) Old 02-13-2006, 07:58 PM
Just make sure it doesn't eat the paint!!
rider76 is offline
post #15 of 17 (permalink) Old 02-25-2006, 10:16 PM
I just cleaned my wheels on my 2001 R1 with brake cleaner in red can and it looks brand new afterwards. I sprayed it on a piece of rag and followed it up with Pledge. Wheels are not only shiny like a brand spanking new set but also glossy when you run your finger on them. Now that the gunk is gone, I just maintain it with Pledge.
sleeper_red is offline
post #16 of 17 (permalink) Old 02-25-2006, 10:28 PM
post #17 of 17 (permalink) Old 02-25-2006, 10:35 PM
I think the break cleaner your talking about is Breakleen... it's in a red can or green for the non clorinated (spelling ) stuff...
I use that stuff for EVERYTHING... though haven't used it on my bike... yet...
