oil light on after fall - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 6 (permalink) Old 02-20-2006, 02:19 AM Thread Starter
I dropped my 03 cbr a while ago and ever since then my oil light is on but the motor runs fine and there are no oil leaks and ive done a few oil changes since, Would you guys happened to konw what happened or why my oil light stays on after i droped my bike?
2k6r6rider is offline
post #2 of 6 (permalink) Old 02-20-2006, 03:11 AM
Probably broke the wire to the low purser sensor most likely near the gauges. Check any damaged areas for hidden damage like a wiring harness or even just one or two wires.
post #3 of 6 (permalink) Old 02-20-2006, 10:38 AM
Good tinkin there Jeeps. But depending on the position of the actual sensor he could have broke the wire right at the sensor. Which would be located on the block..somewhere under the fiarings...
Plus in case I missed your first post!
post #4 of 6 (permalink) Old 02-20-2006, 07:50 PM
Yea, welcome and hang around cuz
rider76 is offline
post #5 of 6 (permalink) Old 02-20-2006, 10:26 PM
Jeeps in the right track, but the wire probably isn't broken - it's shorted to ground.
post #6 of 6 (permalink) Old 02-20-2006, 10:32 PM
2k6r6rider
with all the above, since they are all possible causes.
