SV riders- - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 39 (permalink) Old 03-02-2006, 05:05 PM Thread Starter
SV riders-
Who rides a 120/70/17 front tire on their Sv? I know track guys with one have to if they want decent rubber, so does it change much or can you tweak a few things to make up for it?
post #2 of 39 (permalink) Old 03-02-2006, 06:25 PM
Guideon72's Avatar
I can't really answer that one for ya, JK...but you should swing over to http://www.svrider.com/ and ask around there. You're likely to get at least a few useful hits there.
-G
Guideon72 is offline
post #3 of 39 (permalink) Old 03-02-2006, 06:37 PM
that's where I sold 85% of my sv parts! I always ran the 120/60/17.
post #4 of 39 (permalink) Old 03-02-2006, 08:21 PM
Why would you want to switch the stock size?
post #5 of 39 (permalink) Old 03-02-2006, 08:26 PM
Well i don't have an SV but I do have a 120/60. The 60 series causes the bike to kinda dip (for lack of better terms) into turns more while the 70 series smooths all that out. I'm going to the 70 once I get new rubber. The front will have to be lowered like 8mm to compensate for the change.
post #6 of 39 (permalink) Old 03-02-2006, 08:40 PM
That's what I don't get... it you want more turn in... go to a 110/60 if you want less turn in... why not just go to a 130/60...
post #7 of 39 (permalink) Old 03-02-2006, 08:44 PM
Guideon72's Avatar
You might also try getting a hold of Laura or Roach over at Speedwerks...Something tells me they *might* know a thing or two about this specific issue
-G
post #8 of 39 (permalink) Old 03-02-2006, 08:51 PM
The 120/60 to 120/70 has been more popular. You have more rubber on the sides and you can lean more with more rubber contacting the ground.
post #9 of 39 (permalink) Old 03-02-2006, 09:17 PM
More rubber down...
post #10 of 39 (permalink) Old 03-02-2006, 09:22 PM
It's a taller tire so there would be more rubber on the sides during the lean angle. **** i don't know. That's just what I thought. It seemed obvious.
post #11 of 39 (permalink) Old 03-02-2006, 09:36 PM
But you don't have more rubber on the ground with taller side walls...
You just have more rubber to buckle under the pressure...
maybe somebody else will clarify...
post #12 of 39 (permalink) Old 03-02-2006, 09:42 PM
The sidewalls aren't taller. The middle of the tire is taller.
post #13 of 39 (permalink) Old 03-02-2006, 09:43 PM
I understand where you are trying to get at JK. I know when I had the metzler front tire the freakin curve on the tire just dropped off flat which cause me to have hardly any curve to ride on in a tight turn. That all changed when I went with the Pirelli Diablo I had a nice smooth rounded edge to ride on in a tight turn.
I'm not so sure a 70 series would fix the problem! The tire will flex a little more, but I think it all depends on the way the curve of the tire is shaped.
post #14 of 39 (permalink) Old 03-02-2006, 10:18 PM Thread Starter
thanks for the replys
im working towards making my bike a track bike. i try to modify in that direction. And there are no race tires made in 120/60/17, just 120/70/17. So im looking to start running the 70's on the street to have the rest of the bike set up accordingly. so id like to know what to expect along with the change.
i was thinking the same, but wouldnt it be 10mm?
post #15 of 39 (permalink) Old 03-02-2006, 10:20 PM
Not sure. I'll have to check. i seen it on a how-to on another forum and I think he said 8. You could be right though. I did have a chance to ride an '05 R6 and you could definately tell the difference. It felt real nice.
post #16 of 39 (permalink) Old 03-02-2006, 10:25 PM
http://www.r6messagenet.com/forums/s...ad.php?t=26121 I got 8mm on this one. On some bikes, like the older R6's you have to mod the front fender for the new tire height. People were thrashing their fender and would have to raise it a lil.
post #17 of 39 (permalink) Old 03-02-2006, 10:50 PM
Yes it is... the 120 is the size in mm of the tread... then its 60 (or 70) % of that width for the side wall then the tire rating and rim size
See here!
post #18 of 39 (permalink) Old 03-03-2006, 12:08 AM Thread Starter
works out to 16mm more sidewall going from the 60 to the 70. With that, is there a formula or rule to determine the fork rise?
post #19 of 39 (permalink) Old 03-03-2006, 12:13 AM
See here!
So it's taller and wider. The wider it is the more rubber contact in turns. I know it says 120 for both, but it is taller. it'd have to be because With an MC tire if you just go wider then the curve is gonna suffer and there goes your turning. Plus I've seen them in person.
post #20 of 39 (permalink) Old 03-03-2006, 12:17 AM
The brand has allot to do with it. Some have a round profile while others have a sharp profile.
