Chain Links - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 19 (permalink) Old 03-06-2006, 03:56 PM Thread Starter
Chain Links
What is the proper way to count chain links. I was wanting to get a new chain instead of going to the dealership who has done it before I was going to order it myself. I has a 10'' xtended swingarm and was coming up with a figure of 70 links does this sound about right? Thanks flipmo
flipmo is offline
post #2 of 19 (permalink) Old 03-06-2006, 04:00 PM
An average new chain comes 120 links. I guessing your going to need another 50 on top of that.
post #3 of 19 (permalink) Old 03-06-2006, 04:10 PM Thread Starter
how do you get that figure?
flipmo is offline
post #4 of 19 (permalink) Old 03-06-2006, 04:20 PM
I know what the length of the average new chain is and the rest is just a guess.
Take some string and measure the distance all the way around. Then measure the string. Call the shop and give them the measurements. The should be able to convert it to links. Always order 5 to 10 links long. Its safer and easier to cut than have 2 weak links.
We have several stretched bikes and some good wrenches. If you give make, model and tooth count off sprockets for bike. They may be able to tell you exactly how much chain you need.
post #5 of 19 (permalink) Old 03-06-2006, 04:34 PM Thread Starter
1994 gsxr 750 10'' strech rear sprocket 43t front 14t.
flipmo is offline
post #6 of 19 (permalink) Old 03-06-2006, 08:27 PM
Lets just say...that's ALOT of chain!
What size are you looking for? 520, 525, 530, 560???
post #7 of 19 (permalink) Old 03-06-2006, 08:53 PM
KillerTiller's Avatar
chain
do you have a chain on it know? cause i have a 98 GSXR750 stock swingarm i have a 110 link 525 chain....
KillerTiller is offline
post #8 of 19 (permalink) Old 03-06-2006, 08:53 PM
chain
do you have a chain on it now? cause i have a 98 GSXR750 stock swingarm i have a 110 link 525 chain....
post #9 of 19 (permalink) Old 03-06-2006, 08:55 PM
you counted the links wrong your looking at a 140 link chain not a 70...
post #10 of 19 (permalink) Old 03-06-2006, 09:02 PM
That's what I was thinking but the numbers don't add up.
post #11 of 19 (permalink) Old 03-06-2006, 09:13 PM Thread Starter
I'm looking for a 530 chain I thought that I counted wrong that's why I was wondering the correct way to count it. I do have a chain on it now but I just did all new sprockets and wanted a new chain. Thanks for all the help guys.
flipmo is offline
post #12 of 19 (permalink) Old 03-06-2006, 09:14 PM
Yea remember you gotta count the outer AND inner links, not just the outers to get the correct measurement. Mine stock is 108 links, so like Jeeps said you're probably looking at minimum 160+, but get extra and you can cut it down later to just the right length
thirdgenlxi is offline
post #13 of 19 (permalink) Old 03-06-2006, 09:32 PM
I always just counted the outside links and times it by 2!
post #14 of 19 (permalink) Old 03-06-2006, 09:45 PM
Can someone put a diagram up of what you should count? Just to make it clear to everyone.
post #15 of 19 (permalink) Old 03-06-2006, 11:45 PM
Imagine this is a chain. It would have 7 links.
Name:	chain illustration.JPG
post #16 of 19 (permalink) Old 03-06-2006, 11:46 PM
Awesome pic. You musta went to art school for years. J/K. Thanks. i woulda counted my chain wrong if I didn't see that.
post #17 of 19 (permalink) Old 03-06-2006, 11:52 PM
Glad you liked it and hope it helps you and others more than it amuses.
post #18 of 19 (permalink) Old 03-07-2006, 07:58 AM
Yep... but I usually just count the faces and double my number! If you are going to cut the chain yourself..on the bike... it doesn't really matter what the number is... you just put the chain on and mark where the cut needs to be and do it!
post #19 of 19 (permalink) Old 03-07-2006, 05:45 PM
theres a diagram floating around the web ive seen a hundred times but now i cant find it.
anyway jeeps' is muuuuuuuuch better.
