bike won't fire... - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 24 (permalink) Old 03-09-2006, 12:33 PM Thread Starter
bike won't fire...
i went down to start up the bike today. i just put the battery back in it yesterday. it was on the trickle charger all winter long. now the bike won't fire. i am waiting for the father-in-law to come check it out, until then i thought i'd get advice from my gang here. all the lights come on and it sounds like it is gonna fire, but then it makes this horrible grinding sound coming from right around the battery area. what could it be? i put the battery back in myself this year, usually i have my husband do it (i am trying to be more self-sufficient this year). did i do something wrong? i hooked it up just like the book said, red +, black -. anyways, this puts a damper on any riding i wanted to do today. thanks for your help gang.
itgirl25 is offline
post #2 of 24 (permalink) Old 03-09-2006, 12:41 PM
be sure you have all conditions correct to start.
Ie.. Kickstand Down if in gear, Clutch in if in gear, Key on as well as toggle, It wouldnt hurt to flip the toggle a couple times to ensure connection has been made from sitting. And also you may want to get a tester on the battery to see that the charge took and didnt burn or damage a cell. Good luck,
Earlzach is offline
post #3 of 24 (permalink) Old 03-09-2006, 12:41 PM
Did you miss any little wires at the battery? IDK about you bike but some have small ground wires and hot wires that have to be attached also.
post #4 of 24 (permalink) Old 03-09-2006, 12:44 PM Thread Starter
thanks guys, i'll try all that stuff and see if i have any luck before the f-i-l looks at it. if it is the battery being bad, i'll be upset. i took such good care of it all winter long.
itgirl25 is offline
post #5 of 24 (permalink) Old 03-09-2006, 01:14 PM
Once you know everything is right... try to jump it off your car... the battery could have been on a trickle charger all winter and still be junk!
post #6 of 24 (permalink) Old 03-09-2006, 01:15 PM
and sometimes the trickle chargers quit.
post #7 of 24 (permalink) Old 03-09-2006, 01:17 PM
If the jump start works. Take the battery to the parts store or shop to get it tested.
post #8 of 24 (permalink) Old 03-09-2006, 03:11 PM Thread Starter
well, my father in law did get it to fire up with the jumper cables. but once it stalled out it wouldn't restart. he measured the output with some fancy machine he has and told me that it officially took a puke. so my husband is off to the battery store to check on getting me a new one. so no riding for me today. maybe tomorrow...
itgirl25 is offline
post #9 of 24 (permalink) Old 03-09-2006, 03:11 PM Thread Starter
oh yeah, and thanks to all for your help. much appreciated!
itgirl25 is offline
post #10 of 24 (permalink) Old 03-09-2006, 10:10 PM
Yeah I told ya... bad battery. Sometimes its not good to leave a bike on a trickle all winter. I know I never do. Just take it off the bike and put it on the trickle charger like a few weeks before wanting to get the bike out!
post #11 of 24 (permalink) Old 03-09-2006, 10:18 PM
that sucks IT! So did your husband find you a new battery?
post #12 of 24 (permalink) Old 03-09-2006, 10:28 PM
There's no greater feeling when a fix is fixed. There's no worse feeling when you're trying to ride and your bike is dead. At least you know what's wrong.
post #13 of 24 (permalink) Old 03-09-2006, 10:57 PM
Yep
And that thingy that he put on the battery was most likely a "load tester" it will tell you if you need to go potty or not!
post #14 of 24 (permalink) Old 03-10-2006, 01:08 PM Thread Starter
well, my hubby got me a new battery last night. it was on charge overnight. i am gonna put it in today and see how she runs. i think this winter i will not be leaving it on the trickle charger the whole time. who'd thought that could be a bad thing. but i am all set for now and should be back on 2 wheels here real soon. thanks for the support, gang!
itgirl25 is offline
post #15 of 24 (permalink) Old 03-10-2006, 01:10 PM
i thought new batteries came charged?
dnyce is offline
post #16 of 24 (permalink) Old 03-10-2006, 03:33 PM
You have to add the acid and then charge for 12 hours.
post #17 of 24 (permalink) Old 03-10-2006, 03:39 PM
Yeah what he said!!
post #18 of 24 (permalink) Old 03-12-2006, 06:03 PM
oh? neva knew that, i added the acid and just put it in, neva had a problem.
learn somethin new everyday i guess
dnyce is offline
post #19 of 24 (permalink) Old 03-12-2006, 10:38 PM
They have a dry test charge from manufacture. Its usually enough to get you going. Its just highly recommended to pre charge most MC batteries before install.
post #20 of 24 (permalink) Old 03-12-2006, 10:45 PM
so did the bike ever start? We need updates!
