drive sprocket headache - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 34 (permalink) Old 03-26-2006, 08:18 PM Thread Starter
i cant stop the drive sprocket from moving when i try to remove the nut. Its in 6th, and the rear brake is being applied, but i pull through it. Any other way to hold it still while i try to brake the nut loose?
post #2 of 34 (permalink) Old 03-26-2006, 09:14 PM
You could try first gear for more compression resistance. Its best to use an impact wrench for this task.
post #3 of 34 (permalink) Old 03-26-2006, 10:18 PM
JK, I had this problem too. You need to use a really fast torque impact wrench to make it easier. I didn't have one so I got a big breaker bar and yanked up as hard and as fast as I could until she broke loose. Also you did bend the big fender washer up and away from the nut right?
post #4 of 34 (permalink) Old 03-26-2006, 10:48 PM
Reverse thread?
post #5 of 34 (permalink) Old 03-26-2006, 11:04 PM
Originally Posted by DLITALIEN
Reverse thread?
nope.
post #6 of 34 (permalink) Old 03-26-2006, 11:21 PM Thread Starter
i did bend the washer. That thing is a pain. Id rather it was the 2 tab washer and not the round-bend-it-up kind. Did you have it in 1st? Well i just put the new chain on and the FR sprocket will have to wait. Finally got to ditch the clip-type and get a rivet type. Not that theres anything wrong with a clip type, but it was done for and the RTV silicone finally fell off the master link.
post #7 of 34 (permalink) Old 03-26-2006, 11:58 PM
so I take it you got the nut off?
I just remember bending the washer up flat against the back side, then putting a big socket on the nut, then grabbing a breaker bar and yanking up hard and fast then the nut broke loose with no problem.
post #8 of 34 (permalink) Old 03-27-2006, 11:08 AM
A impact is the only way! Forget it any other way!
post #9 of 34 (permalink) Old 03-27-2006, 11:36 AM
post #10 of 34 (permalink) Old 04-03-2006, 10:31 PM
If you use an impact gun, DON'T LEAVE IT IN GEAR!
post #11 of 34 (permalink) Old 04-03-2006, 11:21 PM
JK_DILLA
Did you ever get it changed?
post #12 of 34 (permalink) Old 04-04-2006, 05:05 AM Thread Starter
Originally Posted by jeeps84
JK_DILLA
not yet. im giving it another go this weekend. I was going to do it last weekend but rode to New Orleans instead.
post #13 of 34 (permalink) Old 04-04-2006, 09:02 AM
Yeah I imagine its not good for the gears.
post #14 of 34 (permalink) Old 04-04-2006, 10:55 AM
LOW TECH SOLUTION.................
Measure the distance betwwen the sides of the swingarm at the front of the rear wheel. Now go cut a piece of 2X4 that width, and place it between the wheel and the swingarm, acting as a block to the wheel turning, and set the rear brake. Now go apply torque to the nut; it'll come loose quite easily, you won't need an impact hammer, and you wont mar your wheels, or damage the tranny.
Sometimes, low tech is best.
OTB
oldetymebiker is offline
post #15 of 34 (permalink) Old 04-04-2006, 11:37 AM
OTB
Great advice!
post #16 of 34 (permalink) Old 04-04-2006, 01:44 PM
Good alternative OTB!
post #17 of 34 (permalink) Old 04-05-2006, 11:09 AM Thread Starter
OTB
i'll try that, thanks-
post #18 of 34 (permalink) Old 04-06-2006, 02:52 PM
I don't understand...The torque on that nut is only 60 to 75 ft.lbs. 99birdv6 and I changed his front (went -1) and it came right off and we had new one installed in less than 10 minutes...
post #19 of 34 (permalink) Old 04-06-2006, 02:59 PM
March 2008 BOTM Winner!
pickle.of.doom's Avatar
Someone may have cranked his on in the past.
pickle.of.doom is offline
post #20 of 34 (permalink) Old 04-06-2006, 07:17 PM Thread Starter
Clymers manual says the nut is @ 105 ft-lb.
