cleaning the chain - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 28 (permalink) Old 04-03-2006, 08:44 PM Thread Starter
cleaning the chain
what do you guys use to clean the chain? thanks.
sleeper_red is offline
post #2 of 28 (permalink) Old 04-03-2006, 09:25 PM
I use WD-40 to clean it and then some chain lube or wax to protect it.
post #3 of 28 (permalink) Old 04-03-2006, 09:51 PM
EIDROEDYR's Avatar
and I use Honda's HP Chain Lube. It's a spray on that doesn't fling off.
EIDROEDYR is offline
post #4 of 28 (permalink) Old 04-03-2006, 10:05 PM
with the bike on a rear stand and not running, just rotating by hand. I may use a small tire brush if its real dirty too. Then comes the new lube.
post #5 of 28 (permalink) Old 04-04-2006, 05:36 AM Thread Starter
thanks guys.
post #6 of 28 (permalink) Old 04-04-2006, 07:38 AM
Wockman's Avatar
+1 on the WD-40 I use it on just about everyting that moves. (pegs, sidestand ect...)
and +1 on the Honda HP, the big can has lasted me over a year so far.
I've been told to clean my chain with only kerosene, but WD-40 works great and it a lot easier to work with. This reminds me that I am overdue to clean my chain, well my whole bike actually needs a good scrubbin'...
Honda CBR1100XX Blackbird
Wockman is offline
post #7 of 28 (permalink) Old 04-04-2006, 08:15 AM
Yeah got use a rear stand... and NEVER EVER do it running. Many have lost fingers by this "great idea".
I would say it depends on the type of chain.
On a standard non "O-ring" chain I used WD40
On a O or X ring chain I use kerosene as it will clean without drying it out. Further sense its a clean oil it has a small lubing factor as well.
post #8 of 28 (permalink) Old 04-04-2006, 09:39 AM
I've seen a few people let their rear wheels turn at idle. Not for me. I won't take the chance of my fingers get pulled in.
I use Motul chain cleaner and chain lube.
fnfalman is offline
post #9 of 28 (permalink) Old 04-04-2006, 05:22 PM
Another +1 for HP lube and kerosene to clean. I'm sure WD-40 works good too. Also, WD-40 works great on wheels(especially if they are black). Leaves a nice shine and a film so the fling from the chain doesn't stick as bad.
Bandit 6S is offline
post #10 of 28 (permalink) Old 04-04-2006, 06:46 PM
WD-40 to clean, then lube with PJ-1 black.
post #11 of 28 (permalink) Old 04-05-2006, 07:35 AM
PJ is good stuff... but it still flings...
Like I said... I point out the difference in chains get a difference in cleaning chemical.
post #12 of 28 (permalink) Old 04-05-2006, 09:06 AM
611 to clean. I then use Motul Chain Lube. Spray the lube towards the botton of the rear sprocket and rotate the tire backwards. It lets the lube work its way down. I let it sit for 10-15 min before riding and havent had any flinging problems.
post #13 of 28 (permalink) Old 04-05-2006, 09:28 AM
How often are you guys giving it a cleaning vs. just lube. I lube mine on a regular basis...but I don't clean very often
post #14 of 28 (permalink) Old 04-05-2006, 10:00 AM
Wockman's Avatar
I try to give the chain a few quick sprays of lube every other tank of gas or if it looks dry at all. But I clean the chain when I wash the bike, or if it looks unusually dirty, which isn't too often.
Wockman is offline
post #15 of 28 (permalink) Old 04-05-2006, 11:01 AM
EIDROEDYR's Avatar
I do both every time which is usually every several 100 miles (500 or so).
post #16 of 28 (permalink) Old 04-05-2006, 01:53 PM
Here is a great how-to: http://motorcycleinfo.calsci.com/Chains.html
I've used the Scott unit, and my chain lasted almost forever. But it is a little pricey.
oldetymebiker is offline
post #17 of 28 (permalink) Old 04-05-2006, 10:27 PM
When I had one I use to try to do it like every other week... which is basically when I thought of it and had time.
post #18 of 28 (permalink) Old 04-05-2006, 10:38 PM
I always use a rag soaked in kerosene.
WD-40 is a solvent.
Mojo is offline
post #19 of 28 (permalink) Old 04-05-2006, 10:40 PM
That's the reason I don't like WD-40 on o or x-ring chains.... I'm affraid it will dry out the rings...
post #20 of 28 (permalink) Old 04-05-2006, 10:44 PM
Exactly my point!
Mojo is offline
