98 GSXR 600 Wont Start - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 5 (permalink) Old 04-22-2006, 04:54 AM Thread Starter
Hello All.......HELP!!!!
I recently bought a used 98 GSXR 600...and it is all of a sudden not starting... I had it running ok then it seemed to choke up an stall..now it wont even crank over. Also the fuel pump does not seem to be "priming" ie when i turn key to "run" I cannot hear the pump wind up....I am suspecting posibily a relay or somthing but am really out of my depth and would GREATLY appreciate some advice on the cause or the process of elimination i could take to determine the prob...Thanks in advance
Scooter17 is offline
post #2 of 5 (permalink) Old 04-22-2006, 08:33 AM
No cranky...no battery juice. Start with battery. Might be a relay, but doubt it. If it won't even crank over, it doesn't have enough juice. When you turn the key, do you get dash lights? If yes,, what happens when you push the starter button?
oldetymebiker is offline
post #3 of 5 (permalink) Old 04-22-2006, 12:34 PM
to TWF
Like was already stated. Check the battery. The fuel pump only comes on when needed too.
post #4 of 5 (permalink) Old 04-22-2006, 02:52 PM
Time for some jumper cables
Gr1n1n is offline
post #5 of 5 (permalink) Old 04-23-2006, 10:29 AM
That's the first place I'd start!
