2004 gsxr 1000 wont start - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 5 (permalink) Old 04-23-2006, 05:36 PM Thread Starter
i got a gsxr1000 2004, the engine runs fine when i pop start it..... but something is effed up with button, it wont work... i get nothing when i push it. what could this be..... i thought kick stand switch, clutch.. relays. i dunno. help me please. i wanna ride and not have to run down the street like a jack ass to start my bike. thanks
Kylesk8hardcore is offline
post #2 of 5 (permalink) Old 04-23-2006, 06:13 PM
Won't start
Do all your electricals come on when you turn the key? And you said that you were disengaging the clutch when you tried to start the bike, right?
If it's not your battery, then have you check your fuses--ALL your fuses?
Just some ideas.
Hotshoe is offline
post #3 of 5 (permalink) Old 04-23-2006, 09:33 PM
Start simple and cheap and work your way up: Starter fuse OK?, Check starter relay; Relay OK: Check Starter switch (yes, they do go bad or get broken). Also, check the CONNECTORS....sometimes thes get loose or a wire gets broken from incorrect routing, or somebody pulls on 'em too hard and breaks a wire. If the bike bump starts, you are getting juice to the EFI and Ignition, so it's something in the STARTER CIRCUIT. Sounds like a loose wire or burned out/loose fuse or relay. I once had a Honda that wouldn't start; when I took apart the handlebar starter switch, broken plastic pieces fell out.
oldetymebiker is offline
post #4 of 5 (permalink) Old 04-23-2006, 11:39 PM
Also, make sure you're in Nuetral when trying to start it....
post #5 of 5 (permalink) Old 04-23-2006, 11:49 PM
tp TWF
Make sure battery cables are tight and clean also.
