gear ratio question - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 5 (permalink) Old 05-16-2006, 03:09 AM Thread Starter
gear ratio question
how do u read the gear ratios? heres one from the 06 r6 for first gear 31/12 (2.583)...and for 2nd 32/16 (2.000)
2eyesforaneye is offline
post #2 of 5 (permalink) Old 05-16-2006, 04:27 PM
Moved to Tech section for more help.
post #3 of 5 (permalink) Old 05-19-2006, 05:21 AM
its just like any other ratio. the 31-12 is the number of teeth on the main shaft of counter shaft. the 31 being the main and the 12 being the counter and then the 2.583 is how many times the counter shaft(12) has to spin in order for the main shaft(31) to spin 1 time.
but the best and cheapest way to play with the gearing on the bike is to leave the trany gears alone since you have to split the blocks apart to get a them, you should play with you drive and driven gears(what the chain is on) for a better top end go 1 up in the front and 1 down in the rear, for better acceleration go 1 down in the fron and 1 to 3 up in the rear.
duceater is offline
post #4 of 5 (permalink) Old 05-19-2006, 08:06 AM
And go -2 in the front and +11 in the back if you wanna be a stunta...like birdman...
post #5 of 5 (permalink) Old 05-19-2006, 08:47 AM
ya thats my next toy. i want to play around with that a bit, or turbos
duceater is offline
