hopefully final thread for the ninja 1000R - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 10 (permalink) Old 05-21-2006, 06:54 PM Thread Starter
Now that I've reassembled the bike, and tried to start it, there seems to be something causing MASSIVE drain on the battery. when I say massive, I mean you can crank it for one second and you're nearly at a dead battery. it sounds like the starter is either weak, or something, but I really dont know.
post #2 of 10 (permalink) Old 05-21-2006, 07:00 PM
Check all your wiring, could be something shorted.
post #3 of 10 (permalink) Old 05-21-2006, 07:31 PM
is the battery new? It could have a bad cell.
post #4 of 10 (permalink) Old 05-21-2006, 08:13 PM Thread Starter
the battery is brand new. I charge all batteries to be sure nothing is wrong with em. but I think you're right. for now though, it'll have to do, since I cant spend any money on a new battery till I have money to spend.
post #5 of 10 (permalink) Old 05-21-2006, 08:17 PM
I've bought "new" batteries that were bad before. I took them back for an exchange with no problem.
post #6 of 10 (permalink) Old 05-22-2006, 10:24 PM
Did you put in the acid yourself?
Did you follow the directions?
Did you put the new battery on the proper charge, on the correct amps and time?
post #7 of 10 (permalink) Old 05-25-2006, 08:09 PM
Almost has to be a bad battery or weak starter. Any short that large would create alot of heat very fast, you'd probably see some smoke from burnt wiring.
mlkx3 is offline
post #8 of 10 (permalink) Old 05-25-2006, 08:14 PM
Motor was wasted.... see here
post #9 of 10 (permalink) Old 05-25-2006, 08:20 PM
Dam!
mlkx3 is offline
post #10 of 10 (permalink) Old 05-25-2006, 10:57 PM Thread Starter
yeah. if I had the cases, or a way to fix the ones there now, I'd rebuild it, but since I havent those parts, I'm selling it. I'm hella mad bout the motor doing what it did, which pushed me to beyond my breaking point.
