motor difference - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 16 (permalink) Old 04-02-2005, 04:50 PM Thread Starter
motor difference
i was just wondering if anyone knows whats the difference from the 00-01 motors to the 02-03. since i have a 01 bike and am looking for a used motor i wanna try and find out what will work. from what i have been told so far is that all four years will bolt in the same but the electronics may or may not be the same. anyone know about this? or where i may find out?
Tresguey is offline
post #2 of 16 (permalink) Old 04-02-2005, 05:27 PM Thread Starter
well i looked up parts for the electrical and fuel injection for the 00-03 on a web site. well all the part numbers are the same. so would it be right to assume that a 03 motor would run in a 00 frame and electrical?
Tresguey is offline
post #3 of 16 (permalink) Old 04-02-2005, 08:52 PM
motors of what?
post #4 of 16 (permalink) Old 04-02-2005, 10:17 PM
Originally Posted by JK_DILLA
motors of what?
Good Point JK!!! For what bike?? I figure its a GSXR but let's make sure....
post #5 of 16 (permalink) Old 04-02-2005, 11:43 PM
It doesn't matter what for. If all the part #'s match then it should work.
post #6 of 16 (permalink) Old 04-03-2005, 12:48 AM
if hes talkin about ford motorcycles then i doubt it.
post #7 of 16 (permalink) Old 04-03-2005, 07:48 AM Thread Starter
oops that was a little bit of a mistake. LOL i should of let you all know that i was talking about a gsxr 750. my bad.
Tresguey is offline
post #8 of 16 (permalink) Old 04-03-2005, 08:49 AM
Well I got the GSXR part right.... Twisty owns 2 750's.... one in a 600cc frame and a 2001 750.... he could tell you more...but won't be able to till probably Monday. Him, MP, Pippi, Dyno, and a bunch more WOS are all at the track this weekend!!! GO WOS!!
post #9 of 16 (permalink) Old 04-03-2005, 11:38 AM
I thought it was slow around here.
post #10 of 16 (permalink) Old 04-03-2005, 09:51 PM
Yep...when you take away a bunch of WOS it really affects things!!! The WOS board has been dead sense Friday afternoon... Oh well!
post #11 of 16 (permalink) Old 04-06-2005, 07:33 PM Thread Starter
does anyone know if there is a electrical difference on the 00 - 03 gsxr 750?
Tresguey is offline
post #12 of 16 (permalink) Old 04-06-2005, 09:07 PM
There isnt any. I look @ the diagrams of both and different execpt the ohms on the ingnition...WHY?
post #13 of 16 (permalink) Old 04-07-2005, 03:26 AM Thread Starter
the reason why i ask is because i wanna do an engine swap and i want to know which are able to be swapped with a 01 gsxr 750. also i wanna put a PCIIIusb on it as well. the tech reps for powercommander said it is not possible since they are different. from 01 to 02. i just dont see the difference. maybe they are wrong.
Tresguey is offline
post #14 of 16 (permalink) Old 04-07-2005, 05:21 AM
I have swapped parts between both and never had a problem. But the dyno jet guys might know somthing I dont. The best things to would get the manual for both and compare them wire by wire, which might take a while.
post #15 of 16 (permalink) Old 04-07-2005, 10:36 AM
I would say it has to do with fuel and spark between the two sizes of CC's.
Are the ECM's the same part # on both?
post #16 of 16 (permalink) Old 04-07-2005, 08:00 PM Thread Starter
i checked and they are the same ecm they only difference i seen was a couple of resisters for the ignition.
Tresguey is offline
