600 to 750 Engine Swap - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 11 (permalink) Old 11-21-2007, 07:28 AM Thread Starter
Set-Up: A friend of mine wrecked his Kat 750. He is OK but the bike is toast. He asked if I wanted to buy the engine to put in my Kat 600.
Question: Is it possible / adviseable to swap a 600 for a 750 on a Katana? Both bikes have been maintained well.
Thanks,
jdKatRider
jdKatRider is offline
post #2 of 11 (permalink) Old 11-21-2007, 11:12 AM
well i suppose the first real question here is how mechanically inclined are you?
Daveon2 is offline
post #3 of 11 (permalink) Old 11-21-2007, 01:05 PM
I dont know if your bikes are the same years, but if they are, the swap MAY be easy.
if you're not mechanically inclined though, dont even ATTEMPT it.
post #4 of 11 (permalink) Old 11-21-2007, 02:53 PM Thread Starter
Thanks for the concern about my mechanical ability. I can handle any mechanical task except welding, and I know people who can do that for me.
jdKatRider
post #5 of 11 (permalink) Old 11-21-2007, 02:56 PM
if they are the same year the frames should be the same check the engine mount points see if they match up before ya do.
papapoi is offline
post #6 of 11 (permalink) Old 11-21-2007, 03:05 PM Thread Starter
So, it's mostly a function of mounting? What about the exhaust? His is no good. (anymore)
jdKatRider
post #7 of 11 (permalink) Old 11-21-2007, 06:28 PM
they MAY work between motors, but I'm not 100% sure of it. measure everything first.
post #8 of 11 (permalink) Old 11-21-2007, 07:26 PM
If you are going to swap a motor. I'd swap in a GSXR750/600 before a Katana 750 motor. Which I think would be a cool sleeper if feasable. To me it doesn't seem worth the hassel to just drop in a Katana750. I'm not sure how much you'd gain from going to a 750 but unless it allows my Katana to hang with a sport 600 then why? Why go through a lot of effort to put in a 750 motor when all you'll do is hang with other stock Katana 750s.
I'd get the both the Katana 750 and 600 Manuels and read them over to see if there is much of a difference. Also if hte bikes are the same frame then I dont' see why it wouldn't fit.
Atlantasmittie84 is offline
post #9 of 11 (permalink) Old 11-21-2007, 08:52 PM
Kat's were largely the same up until the re-design...which I believe was somewhere around 1998 or so. In theory it should be a relatively easy swap.
post #10 of 11 (permalink) Old 11-25-2007, 10:35 PM
It can be done. Anything can be done. But the trick is, can you do it.
Have you tried www.katriders.com Need4speed is a mod over there.
post #11 of 11 (permalink) Old 11-25-2007, 11:27 PM
biggest trick with that would be finding a place for the radiator and such.
