LED Flush Mount Questions - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 25 (permalink) Old 12-24-2007, 07:40 PM Thread Starter
My Fiance got me some Hot bodies flushies.... and it says that they flash at a high rate of speed to increase visabillity which sounds like . So what size resistor do I need to make them blink normal and where do i install it.
post #2 of 25 (permalink) Old 12-24-2007, 08:00 PM
Lifetime Premium
vabarber2's Avatar
Aww balko no like the techno blinky!!
Congrats!
vabarber2 is offline
post #3 of 25 (permalink) Old 12-24-2007, 10:27 PM
I think it's just inline... just before the signal would be fine I think...
and I agree the high rate of blinking doesn't help anything
post #4 of 25 (permalink) Old 12-24-2007, 11:12 PM
just go to napa and pick up a flasher relay.
post #5 of 25 (permalink) Old 12-25-2007, 12:44 AM Thread Starter
it said in the directions to pick up a resistor... but it doesnt say what size...does anyone know what size.
post #6 of 25 (permalink) Old 12-25-2007, 12:46 AM
hook em p first n see if you like/dislike the flash rate. When I installed mine they didnt speed up to awlful much more than with the stockers.
got this off the cbrforum:
if the signals now flash too fast for your taste go to radio shack and get two 20w by 8 ohm resistors and jump the green ground wire to the turn signal wire (solid color)
this will slow down the blink rate
also are the three wire or two wire flushies? 3 wire would mean you still would have running lights. 2 wire you would loose running light and just have turn signals.
post #7 of 25 (permalink) Old 12-25-2007, 12:48 AM
Hotbodies anything = junk.
Leave the fast flash, it's not bad for the bike at all, and more attention grabbing.
post #8 of 25 (permalink) Old 12-25-2007, 01:00 AM Thread Starter
will it get worse when I add the LED intergrated brake lights... and will inspection stations have a problem with it...
post #9 of 25 (permalink) Old 12-25-2007, 01:02 AM
shouldnt n shouldnt tho I dont really know for sure on the inspection as GA doesnt require them.
post #10 of 25 (permalink) Old 12-25-2007, 01:04 AM
Won't get any worse, will pass inspection.
The fast rate is just the bike's way of telling you it thinks you have a bulb out. Since the LEDs barely present any load, the bike thinks your lights are out, so it blinks them doublefast to let you know in your dashboard indicator. However, it's not bad for the bike, and I personally like it. Adds to your visibility, and increases the chance that if someone glances in your direction and then glances away they will still see one of the flashes.
My rears flash fast. My front flushies don't, since they are proton flushies which have built in compensation that works no matter what you do to them.
post #11 of 25 (permalink) Old 12-25-2007, 01:09 AM Thread Starter
Does anyone know how i can get them to flash normal seeing as I would rather them not be spaztick like that... If its an easy fix i would rather it done right than done half azzed.
post #12 of 25 (permalink) Old 12-25-2007, 01:12 AM
Its not halfassed if ya leave em fast, just person preference, hence why I suggest hook em up n see if you like it or not.
post #13 of 25 (permalink) Old 12-25-2007, 01:22 AM Thread Starter
explain it to me (the electronicly retarded person) where do i put the resistor on the positive side or negative side.... I never really got the whole electronic thingy.
post #14 of 25 (permalink) Old 12-25-2007, 01:25 AM
resistor will go on the positive side. Dont worry I am puter savvy but not very electronically savvy I learn it as I need it.
post #15 of 25 (permalink) Old 12-25-2007, 01:33 AM Thread Starter
alright ill hook em up on xmas if i dont like-em i am going to radio shack and getting resistors to do it right... thanx
post #16 of 25 (permalink) Old 12-25-2007, 01:39 AM
glad to helped
post #17 of 25 (permalink) Old 12-25-2007, 08:38 AM
LIke PG said its all personal preference... on my 9R I left them as fast cause it gave me more blinks per second so that cage knew where I was going.
post #18 of 25 (permalink) Old 12-25-2007, 10:10 AM
March 2008 BOTM Winner!
pickle.of.doom's Avatar
If you change all four out there may not be enough resistance for them to flash at all, they will just come on and stay on.
pickle.of.doom is offline
post #19 of 25 (permalink) Old 12-25-2007, 11:23 AM Thread Starter
thats what i was worried about.
post #20 of 25 (permalink) Old 12-25-2007, 11:25 AM
I'd go with what PFG dug up.
