True HID better than Xenon filled lights? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 7 (permalink) Old 01-31-2009, 07:25 PM Thread Starter
I'm wondering if anyone knows if there is truly a difference between True HID bulbs or the regular Xenon filled kind. The price difference is like 100 dollars so i would really like to know before hand. I know the Xenon kind advertises that the K color (like 8000K or 10000K) are the same but i thought the silvania cool blue bulb would be like that and it ended up being no different than the stock headlight. I've learned to not trust advertising so i need the input.
07zed is offline
post #2 of 7 (permalink) Old 02-14-2009, 01:52 PM
IMO, bulbs will never compare to HIDs.
That is my experience with automobiles; so I fathom the same to be true with bikes. I'm running 8000K HIDs on my truck and will probably go with 6000K kit on my bike
lascrew is offline
post #3 of 7 (permalink) Old 02-14-2009, 05:13 PM Thread Starter
do you know about the color? are the color intensities about the same
07zed is offline
post #4 of 7 (permalink) Old 02-17-2009, 01:20 AM
heres a chart to show u the color scale, or Kelvin scale, ,
and if that doesnt help, here are some pics of real life HID's,
Tom_Cruisin is offline
post #5 of 7 (permalink) Old 02-21-2009, 08:22 PM
If your going with tryin to get a brighter bulb then you for sure should spend the extra and get the HID's. I just put a set of 8000k in my bike. Basically the higher the color the more blue and the lower the more white. A 4300K bulb is white but much brighter than say a 8000K bulb with is bluer (but still much brighter than xennon bulbs). Trust me and go with the HID's!!
ZX10R_NARDI is offline
post #6 of 7 (permalink) Old 04-01-2009, 06:48 AM
Argh
Argh..
For the record, Xenon filled bulbs are powered by a voltage transformator which generates +/- 23.000 volts. This transformation is called High Intensity Discharge (HID) because of the obviously high voltage.
HID is not a different kind of lightning then Xenon because HID is used to power the xenon filled bulb as a starter does to a TL tube (linear fluorescent).
giathicr is offline
post #7 of 7 (permalink) Old 04-05-2009, 08:52 AM
yesit is i have the 6k kit from starrotors.com on my bike
Ratfink is offline
