Rear Brake Lever w/Shorter Platform? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 12 (permalink) Old 05-03-2006, 10:34 AM Thread Starter
jtemple's Avatar
I'm having some trouble getting my brake pedal adjusted where I like it. If I move it down as far as it will go, it's still not far enough out of the way that I don't have to worry about pressing it inadvertently. Also, I discovered that, when adjusted all the way down, it leaves the brake light on continously.
I noticed that sportbikes generally have shorter platform rear brake levers, unlike my SV. I think that would solve my problem, allowing me to comfortably have my toes outside of the lever, instead of over the top of it.
Does anyone know where I can get something like that for my SV? If a lever from another model of bike would fit, that would be what I prefer. I'm not looking for some bling-bling $200 aftermarket part (see my shorty levers thread).
2006 Kawasaki ZX-10R
jtemple is offline
post #2 of 12 (permalink) Old 05-03-2006, 11:32 AM
[IMG]http://rds.yahoo.com/_ylt=A9gnMibb2lhETLYArKCjzbkF;_ylu=X3oDMTBsNXZtZnJ jBHNlYwNwcm9mBHZ0aWQDSTk5OV83Mw--/SIG=12t8nsjmd/EXP=1146760283/**http%3a//www.made-in-china.com/showimages/111/400010599/0/Bench_Grinder.jpg[/IMG]
It was a bench grinder. oh well...
post #3 of 12 (permalink) Old 05-03-2006, 12:05 PM Thread Starter
jtemple's Avatar
Yeah, that's my next step... buy a replacement and grind it.
jtemple is offline
post #4 of 12 (permalink) Old 05-03-2006, 02:19 PM
I have a bench grinder and an angle grinder if you want to experiment?
mlkx3 is offline
post #5 of 12 (permalink) Old 05-03-2006, 02:45 PM Thread Starter
jtemple's Avatar
Sounds good. Let me shop around for a lever to grind first. I'd like a spare in case I screw up.
I have the stuff to do it on my own, if need be. Dremel, Sawzall, Hacksaw, etc. etc.
jtemple is offline
post #6 of 12 (permalink) Old 05-04-2006, 11:50 AM
You should be able to adjust your tail light switch so it doesn't stay on!
post #7 of 12 (permalink) Old 05-04-2006, 02:10 PM Thread Starter
jtemple's Avatar
Well, I would think that the tail light would be hooked up in such a manner that it didn't matter how I adjusted the lever.
I haven't had a chance to get a good look at it yet, but I think it's a matter of stretching the spring on the switch.
jtemple is offline
post #8 of 12 (permalink) Old 05-04-2006, 10:50 PM
No usually there is like a plastic bolt thing as part of the tail light switch...should be able to just adjust that!
post #9 of 12 (permalink) Old 05-07-2006, 11:54 AM Thread Starter
jtemple's Avatar
Adjusted my switch, good to go now!
Thanks!
jtemple is offline
post #10 of 12 (permalink) Old 05-07-2006, 04:03 PM
So after you did that...the full down adjustment you were getting before works for you?
post #11 of 12 (permalink) Old 05-07-2006, 04:23 PM Thread Starter
jtemple's Avatar
Yeah.
jtemple is offline
post #12 of 12 (permalink) Old 05-07-2006, 04:39 PM
Awesome glad I could help.
