I adjusted the rear shock 1.5 turns (to tighten up the spring) from the stock settings. It feels stiffer in the corner like it doesn't "sit down" as much in quick "S" turns.
From those who have adjusted their rear shock, is this too much/stiff. Also include the maximum you have adjusted your rear shock spring and adjusted your rebound/compression settings (mine are two clicks from max on both). Thanks for your input in advance!
jim
jim
