1 - 20 of 30 Posts
Ok, I totalled my bike this fall but i rebuilt the whole thing except for a few key things. It ran the day I started to take it apart( just swapped frames, front suspension and plastics pretty much) Right now I cant get it to start. Its not getting power to the starter, or handlebars right now or something. It is making the sound it should when you put the key in and everything sets up, but when i push to start it, absolutely nothing happens. Can someone show me by taking a picture of their wiring harness under the seat, or does anyone know where exactly the plugs for the starter are and run? thanks for any help.
hold on so are you selling it ??? you have another post about this bike ????? right ???
mods just combine them :thumbs:
Discussion Starter · #4 ·
im not selling the bike right now, i dont think. Im wondering what it would be worth if i did. Who knows tho. I am about $200.00 away from being able to ride it, and 6-700. from it being mint again.
Why don't you just fix it and keep on riding her??!! She's too pretty to let go....even though she's got a black eye or two.... :D
i can get you a pic of my 04 6R. but you wont get it till tommarrow, im at work. let me know where ans what you want pics of. also you can get a manual on a cd for $5 of ebay.
Discussion Starter · #10 ·
Thanks, Im looking for a pic of the wiring harness, right behind the battery. I need to know where a plug goes, but it doesnt connect to a resistor and the one im looking for has a big yellow wire going into a connector tube.
lol this is gonna sound stupid but is just hangs there. there is nothing connected to it. i never messed with anything in there and mine is like that i will take a pic if you want. im gonna check the manual out and try and see what its for.
AFTER further looking into the manual, i think it is a Self Diagnostics connection. its just and open ended connection. does not need to be hooked up.
Discussion Starter · #15 ·
Got the manual cd, and now its almost turning over, its just not quite starting yet. Is there a starter spray for bikes that you can put into the intake and it usually helps? Ive done it to cars but i dont want to risk anything..
if its been a long time since its started did u charge the battery first...normally if it "almost starts" the battery needs more juice to turn the starter at full power.... like has already been said.. Start simple. My friends triumph was "almost starting" after nto beign ridden forever and he was all worried.. i came out with a charger and ten minutes later we went for a ride.
yup i second the check the battery charge before using any type of spray. that ether spray or whatever it is works good if thats the problem but i would not use it for this. theses bikes are to new to need any spray to get them started(it can also screw ur shat up if you use too much). also check to make sure there is spark casue you did have to rewire the bike, right.
Is the bike all togather & on the ground or on stands .,.The reason i ask , is the kickstand down ?? Wont start if its not . tThe kick stand sessor thing needs to be a closed circut .. Is it in nutral ? Just a few simple things to check .
Later Super ..
Discussion Starter · #19 ·
It is trying to start. In other words its turning over just not catching and running. I didnt need to rewire the bike either, The wiring harness remained intact i just thought something was missing that fell off or something when the yellow wire wasnt attached, since i did have to unplug everything( that problem before is now resolved, everything is connected properly and im getting power everywhere!) Anyway, I charged the battery all day today and still it just doesnt quiet start. Anymore sudgestions? The picture attached is how the bike looks currently with the old broken plastics on(Just wanted to see it together again even tho the new plastics havent arrived yet!!!)
test the battery to make sure its good if its sat a while.. plus make sure the starter teet h are good.. not sure how ud check that but sounds like if it is powered then its not cathcing it to turn it over.
1 - 20 of 30 Posts
