1 - 20 of 63 Posts
all i can say it WOW
And check it out, undertail exhaust makes it to Kawasaki (bout bloody time)
Kawasaki’s ZX-6R has been a strong performer for the brand over more than a decade now. The model scored a complete redesign in 2003 and for 2005 the green brigade are again coming out in force with a heavily revised ZX-6R and ZX-6RR.
The most obvious change is the move to bodywork resembling that of the ZX-10R. But Kawasaki are claiming aerodynamic improvements with the updated styling and state that the new machine is the most aerodynamically efficient motorcycle they have ever made. Kawasaki have also followed the trend of fitting an underseat muffler to their supersport machine.
In the engine room Kawasaki engineers have also been working hard with a new cylinder block and head. New oval shaped 38mm throttle bodies feature two injectors per cylinder and Kawasaki claim their new shape throttle bodies free up room while also increasing airflow. In the new cylinder head reside larger intake and exhaust valves which are actuated by new camshafts. The limited production ZX-6RR race machine scores revised intake ports which are polished by the factory and combine with a new combustion chamber design and larger exhaust valves. New pistons swing off a new crankshaft which features larger main journals. A thicker crankcase design has followed Suzuki’s lead with breathing passages milled in to their design to help realise lower crankcase pressures. Other detail changes include revised mountings for the oil filter and new aluminium oil cooler. The oil pump drive ratio has been revised and now draws from a deeper sump.
The gearbox has also come in for attention on both models with stronger internals. The ZX-6R scores a taller third gear while the track destined ZX-6RR now ships with ratios similar to that only seen before in the racing kit gearbox.
Both models feature an upgraded engine management system to control the second set of injectors and also to actuate the new back pressure valve in the exhaust system. Both are equipped with a back torque limiting wet clutch.
The new matt black aluminium frame offers a shortened wheelbase with a longer braced aluminium swingarm now pivoting further forward in the machine which now rolls on a slightly reduced wheelbase.
Showa supply the fully adjustable rear shock while a revised Uni-Trak linkage promises to provide a more linear transition through the stroke of the rear suspension. The 41mm upside-down forks score a trick new surface coating to reduce stiction. On the race inspired ZX-6RR this coating is also applied to internal surfaces of the sliders.
We have seen the radially mounted brake calipers before on this model while the disc rotors have now grown to 300mm in diameter and are of the trick new petal design normally only seen on race bikes. The front master cylinder has also been improved which will be a great relief to racers loyal to the Kawasaki brand. The rear disc now mounts directly on the swingarm.
The previous machines had three-spoke wheels but the new machine arrives with six-spoke rims shod with a 120/65ZR17 at the front and 180/55ZR17 at the rear.
Ergonomics have also changed with the bar to footpeg distance reduced to closely resemble the performance based riding position seen on the ZX-10R open class superbike.
SPECS - 2005 Kawasaki ZX-6R and (ZX-6RR)
Engine: 636cc, liquid-cooled, DOHC, in-line, four-cylinder (599cc on the ZX-6RR)
Bore x Stroke: 68 x 43.8mm (67 x 42.5mm on the ZX-6RR)
Compression: 12.9:1 (13.5:1 on the ZX-6RR)
Induction: EFI with 4 x 38mm oval throttle bodies
Starter: Electric
Transmission: Six speed with back torque limiting clutch
Final Drive: Chain
Fuel Capacity: 17 litres
Tyres: Front _ 120/65ZR17; Rear _ 180/55ZR17
Suspension: Front _ Fully adjustable 41mm inverted telescopic forks; Rear _ Fully adjustable single Showa shock
Brakes: Front _ 300mm discs, radial mounted four-piston calipers; Rear _ 220mm single disc
Price: TBA
Warranty: Two years, unlimited kilometres
Available: TBC
That bike and Kaw rocks. I've been a long time Kaw fan and I'm glad to see them making these huge leaps and bounds in the sportbike scene.
Your right Shan, pretty soon it will be like, "do you remember when they use to hang the cans out here under the passenger foot, that was so lame." And we'll all laugh....
oooooo yeah, this bike is sweet!!! It doesnt seem to flow in quite as much of an egdy way, so to speak, than the other newer ninja's Kaw. is coming out with, and that rounded shape rear is kinda hard to judge in those pics, but still, she's definately a beast. I'll have to check one out soon :yesnod:
wonder who Kawa hired in the front office to get them back into the heat of the battle. whoever it is, is doing a helluva job.
Sweet pics. I like the way the seat sits pretty low and your arse has some support around it. All and all, its a beast of a bike. :)
Ya know, Matt, I was thinking the same thing. Kaw got pretty bad there for a while when the GSXR was blowing up the scene. Then all at once, Kaw was bangin out new bikes with top notch specs. I was like WTF but I was lovin it at the same time, being a die hard Kaw fan.
Not to mention, for Twisty what he says, is saying alot. He's been bangin on my 9R forever. Even after the dyno shoot out last year when I did quite well for the ole girl! He's a tough critic to impress...:lol:
u know twisty, the first step to recovery is admitting your issue.. :rofl: sorry dude, just couldnt resist. ;)
:drool: That thing looks F'in AWESOME! From the flush mounted blinkers, under tail exhaust, and wave rotors....DAMN!!! :drool: :dthumb:
1 - 20 of 63 Posts
