Whatcha think?
MSRP
$7,099* Available from July 2004
Engine
Type
599cc, liquid-cooled, 16-valve, DOHC, inline four-cylinder
Bore x Stroke
62 x 49.6mm
Compression Ratio
12:1
Carburetion
36mm Keihin CV Downdraft Carburetors (4)
Ignition
Digital TCI
Transmission
6-speed w/multi-plate clutch
Final Drive
O-ring chain
Chassis
Suspension/Front
41mm telescopic fork w/adj. preload, compression and rebound damping; 5.1" travel
Suspension/Rear
Single shock w/piggyback reservoir and adj. preload, compression and rebound damping; 4.7" travel
Brakes/Front
Dual 298mm floating discs w/4-piston calipers
Brakes/Rear
245mm disc w/single-piston caliper
Tires/Front
120/60-ZR17
Tires/Rear
160/60-ZR17
Dimensions
Length
81.1"
Width
28.5"
Height
46.9"
Seat Height
31.7"
Wheelbase
55.7"
Rake (Caster Angle)
25.0°
Trail
3.82
Fuel Capacity
5.0 Gallons
Oil Capacity (with oil filter change)
3.07 Qt.
Dry Weight
412 Lbs.
Color
Team Yamaha Blue/White, Liquid Silver
MSRP
Engine
Type
Bore x Stroke
62 x 49.6mm
Compression Ratio
12:1
Carburetion
Ignition
Digital TCI
Transmission
Final Drive
O-ring chain
Chassis
Suspension/Front
Suspension/Rear
Brakes/Front
Brakes/Rear
Tires/Front
120/60-ZR17
Tires/Rear
160/60-ZR17
Dimensions
Length
81.1"
Width
28.5"
Height
46.9"
Seat Height
31.7"
Wheelbase
55.7"
Rake (Caster Angle)
25.0°
Trail
3.82
Fuel Capacity
5.0 Gallons
3.07 Qt.
Dry Weight
412 Lbs.
Color
