1 - 1 of 1 Posts
For all Ducati Superbikes
MW Billet "Ohlins" Triple Clamp Set: 848-1198 30mm
MW Billet "Showa" Triple Clamp Set: 848-1198 30mm offset
MW Billet "Ohlins" Triple Clamp Set: 749/999 30mm
MW Billet "Showa" Triple Clamp Set: 749/999 30mm offset
MW Billet "Ohlins" Triple Clamp Set: 748/998 30mm offset
MW Billet "Showa" Triple Clamp Set: 748/998 30mm offset
These triples have a 30mm offset for better stability and include an aluminum headstock pin and hardware to replace the steel headstock pin. No adapter is rquired.
The 30mm offset adds 6mm of trail, allowing the bike to finish the turn better, allowing you to get on the gas earlier and hold your line better as well as giving you a better "feel" for the front end. The 6mm change shortens the wheelbase making the bike turn faster and with less effort.
Your forks will sit “lower” in the clamps so in effect the bars get raised about 10mm from stock. This is easier on your arms and hands. It is much better for long trips with all the benefits of a perfectly setup bike.
These 30mm triple clamps designed to be interchangable with all Ducati Superbikes with just a fit kit. This will allow you to swap them to another bike or sell the piece much easier down the road.
This triple clamp assembly will not require any modifications to the frame
Available in black and titanium finish only. Pictured unanodized to show details.
Sale Price: $799.00
List Price: $899.00
On sale through JUNE.
1 - 1 of 1 Posts
