1 - 12 of 12 Posts
straight 70 weight......not sure about that. Kinda thick...I wonder if those race bikes have a different oil pump....
I could definately see the plus side once the bike gets hot and the oil thins a bit.... plus, you got the super filter, so bypass shouldn't be as bad due to the higher flow rate on the Scotts filter....
Really! I didn't know that. How would they know? hehe
Anyway, that's not what I'm gettin at. I just want to make sure that your current oil pump is going to scream it's nuts off trying to pump the extra weight/thicker oil. I'm sure it will but it was just something I wanted to toss out.
But I can definately see some great advatages to running the thicker oil. Once it gets hot, it would be heavier than the other. Aren't you runnin 20-50 in it now?!?!? If not that would definately be another avenue I would look at. The 10-40's just wouldn't seem to be enough for the track...
1 - 12 of 12 Posts
