The title explains itself.... My water pump isnt working and my engine is overheating....Theres no rad fluid going anywhere.... How do I fix it?
:iagree:bumblebee said:I'd do thermostat first...when water pumps go out...there is usually evidence of water leaking around the seals
:iagree: check the thermostat first.larryg said:I guess the first question is...how did you determine the water pump is not circulating coolant?
Not enough info...Aesop Ninja said:The title explains itself.... My water pump isnt working and my engine is overheating....Theres no rad fluid going anywhere.... How do I fix it?
