Race gas is a waste of money unless ....
A) You have a motor with increased compression over stock. This will require race gas because you need the higher octane so as not to detonate the hell out of your motor. Or if you're trying to find no-mans land on ignition timing advance - octane will help here, depending on how far you go.
or ...
B) You're buying oxygenated race gas and are mapped/jetted for it. You can buy race gas with anywhere from 2.5% to 10% oxygen in it. On the dyno, you remap/jet for this - more fuel (richer map/jetting) + more air (in the fuel) = more power. Of course, oxy race gas *starts* at about $10 a gallon (and goes up from there).
If you have a stock street bike, you can actually lose HP running race gas as the higher octane and burn characteristics (mainly the speed) are not right for the motor. If you run oxy fuel without remapping, you can be way too lean and burn up your pistons. Also, most race gas is leaded - if your bike has a cat converter on it, you will burn it up.
Put in what your manual tells you to!
- Brian Roach
- SpeedWerks.com
