1 - 4 of 4 Posts
I'm having problem with my gauges. I was changing all four turn signals and when I was done my gauges and the rear running light did not work. I checked my fuse and it was blown. I replaced it and the gauges still do not work. The high beam light indicator goes on as well as the clock. The brake light will go on when brakes are applied. I have checked all connections in the front cowling and they are all good. Please help :screwy:
You probably have multiple fuses blown.... maybe another F4i guy can clarify for ya...
Fuses blow because there is short. The wire from the positive terminal of the battery is being grounded by a pinched or worn wire. When you check your turn signals, you may find a wire(s) that is accidentally touching the frame (ground).
Discussion Starter · #4 ·
I did look at that and then I unpluged all the turn signals and taped each one seperatly.
1 - 4 of 4 Posts
