1 - 19 of 19 Posts
What is the proper way to count chain links. I was wanting to get a new chain instead of going to the dealership who has done it before I was going to order it myself. I has a 10'' xtended swingarm and was coming up with a figure of 70 links does this sound about right? Thanks flipmo
flipmo said:
how do you get that figure?
I know what the length of the average new chain is and the rest is just a guess. :sorry:
Take some string and measure the distance all the way around. Then measure the string. Call the shop and give them the measurements. The should be able to convert it to links. Always order 5 to 10 links long. Its safer and easier to cut than have 2 weak links.
We have several stretched bikes and some good wrenches. If you give make, model and tooth count off sprockets for bike. They may be able to tell you exactly how much chain you need.
you counted the links wrong your looking at a 140 link chain not a 70...
Discussion Starter · #11 ·
I'm looking for a 530 chain I thought that I counted wrong that's why I was wondering the correct way to count it. I do have a chain on it now but I just did all new sprockets and wanted a new chain. Thanks for all the help guys.
Yea remember you gotta count the outer AND inner links, not just the outers to get the correct measurement. Mine stock is 108 links, so like Jeeps said you're probably looking at minimum 160+, but get extra and you can cut it down later to just the right length
Yep... but I usually just count the faces and double my number! If you are going to cut the chain yourself..on the bike... it doesn't really matter what the number is... you just put the chain on and mark where the cut needs to be and do it!
1 - 19 of 19 Posts
