But if you goto to DiD's site, they say anything over a 750 should have a 530. And we all know that the V's have more torque, hence they'll need more durability.
DiD Site
And like Hondaguy said, you are getting a DiD, and they are the best!
However, you will need a chain break to get your old one off the right way, and most of your chain breaks also have the tool that you need to install a DiD replaceable link!! DiD uses replaceable links, because as long as installed correctly, are WAY strong than a master link. You know, a chain is only has strong as it's weakest link!! :wink:
YOU MUST USE THE CORRECT TOOL TO MASH THE REPLACEABLE LINK RIVITS OVER!!!!!!! This is VERY important!!! If you don't, it will come out at the most inopertune (sp?) time, and most likely at some high engine speed. And on it's way out, it will F your bike up!!! I know!!!!! :rant:
