That would be the first thing to check... then steering stabalizer...bumblebee said:maybe it's time to replace the bearings and do a little maint.
Good advice. Don't use a damper to mask other problems...SpeedWerks.com said:Before spending $$$ on a steering stabilizer, you may want to look into some maint and setup as mentioned above. Under normal conditions, an SV shouldn't headshake. While a steering stabilizer might keep this from happening, you're just covering up a problem, not solving it. You might want to check your sag, and make sure the rear isn't too soft. If it's squating under accelleration and unloading the front, it could cause a headshake to happen when you shift (you're unloading the rear and loading the front for a couple seconds).
- Roach
Except you didn't mention to check or stiffen the rear suspension.Gas Man said:Isn't that a basic idea of what I and Bee said??? :scratch:
a couple seconds?!?! I know i shift faster than that!SpeedWerks.com said:when you shift (you're unloading the rear and loading the front for a couple seconds).
- Roach
