1 - 16 of 16 Posts
The bikes that have the under seat locks for your helmets...look like a hook. When you slide the rear seat back on the helmet just hangs off the bike.
fatburg said:
I know my FZ6 does NOT have a lock and it's annoying.
I thought all bikes had the little helmet hook under the rear seat. I'm glad mine does...
:welcome: cmalone.... in the front of the trunk ( in the tail section ) there are 2 hooks. The hooks face inward. With your seat or cowl off you can see these. Hang your helmet on it off the D-tab and then put the seat back on. You will have to go under the left side helmet or thru it to get your key into the keyhole to remove the seat.
It works very well!
It works very well!
The hooks might be attached to the cowl on some bikes. Pulse you can use the cable for a piece of mind.
Not on the 9R... its attached to the subframe... actually its the bolt that goes thru the hook, the tail, and into the subframe.
1 - 16 of 16 Posts
