Hello,
How exactly do you shift while dragging? I have ridden low power bikes and it's ok to reel the clutch in, shift and dump the clutch.
In higher power bikes, is it the same? This might cause wheelies and general instability.
Also regarding clutchless upshifts - Can you do that while doing a drag run?
This is how i upshift without the clutch - Decrease throttle to match engine speed in higher gear at current speed and tap in the gear.Usually at 4-5k rpm.
At higher revs, is it the same or different?
Thanks
Thanks
