KTM USA Models, then onroad..
Engine
Engine double-cylinder 4-stroke V 75°
Displacement (cc) 999
Bore / stroke (mm) 101 / 62.4 (3.98 x 2.46")
Performance (homologated) 88 kW / 9000 rpm
Max. torque 100 Nm / 7000 rpm
Compression ratio 11.5:1
Starter E-starter
Transmission 6 gears, dog-clutch engagement
Carburetor Electronic fuel injection
Control DOHC
Lubrication Pressure lubrication
Engine oil Motorex Power Synt 4T 10W50
Primary drive 67:35
Final drive X-Ring chain 5/8 x 5/16"
Cooling liquid-cooled
Clutch wet multi-disc clutch, operated hydraulically
Ignition Denso battery ignition
Chassis
Frame chromium-molybdenum, powder-coated
Subframe aluminum
Handlebar Renthal aluminum, conified
Front suspension WP-USD 48 mm (1.89")
Rear suspension WP - Monoshock
Suspension travel front/rear 135 / 160 mm (5.31/6.3")
Front brake 2 x Brembo 4-piston caliper, 2 x 320 mm disc (12.6")
Rear brake Brembo 1-piston floating caliper, 240 mm disc (9.45")
Rims, front/rear 3.5 x 17" / 4.5 x 17"
Tires, front/rear 120/70 ZR 17"; 180/55 ZR 17"
Transmission ratio 17:38
Battery 12 V 11.2 Ah
Main silencer stainless steel with controlled catalytic converter
Steering head angle 66.5°
Wheel caster 103 mm (4.06")
Wheelbase 1438 mm (56.61")
Ground clearance (unloaded) 165 mm (6.5")
Seat height 855 mm (33.66")
Fuel capacity approx. 15 liters (3.96 gal)
Weight (no fuel) approx. 184 kg (405.7 lbs)
Engine
Starter E-starter
Control DOHC
Primary drive 67:35
Chassis
Subframe aluminum
