1 - 5 of 5 Posts
I am thinking of getting rearsets for my 1996 F3. Aftermarket stuff seems to be geared for current models. Not my old pig. Anyhow, could someone out there go and measure the distance between mounting bolts on the rearsets on a 2003 to 2005 CBR600RR? Also, how does the shift linkage attach? A pic is worth a thousand words :whistle:
Thanks, Carl
Just make them! :2cents:
Get some aluminum 1" wide and drill holes for the factory placement.
Then drill holes for the new location.
It will move the pegs back 1/2" and up or down depending on how you drill them.
Worked great on my F2 & F3 track bikes.
You may need a new shifter rod if you move them to far. :luck:
1 - 5 of 5 Posts
