1 - 13 of 13 Posts
My 2005 ZX6R calls for 10w40. The average air temps I will see are between 84-94 degrees F. Is this what everone recommends, or should I try something a little different? Also what are everyone's thought's on the best milage to switch to full synthetic, or should I?
I put Pennz 10W40 in the bee...just make sure it does not say energy conserving on the label...look on the back for the circle with the grade letters and numbers. Of course, I change my oil every 6 weeks...probably why it is having open head surgery today...
If you're concerned about it...go with full sync. I suggest Amsoil but that's just my :2cents:
Discussion Starter · #6 ·
When is the best time to switch to a synthetic? I want to make sure that I don't mess with the break in process. So I guess the standard 10w40 would be the best thing to go with, and not a 20w40, or a 10w50 per-say?
Stay with the 10w-40 because your motor is designed for that and the passages are designed for that weight oil as well. I would definately stick with convential thru at least a few thousand miles...but this is a question of the ages!
Like I said a few thousand miles... I didn't use it on my 9R until like 6 or 7 thousand!
1 - 13 of 13 Posts
