GSXR750DJ said:I would say orange.
ShanMan14 said:It reads 30 RPM, so I'm assuming the white wire (I chose) is the wrong one. :cursin:
larryg, any input?
larryg said:Congrats! It would have been a shame if you had to break out some of that TNT
Usually, either wire will work but sometimes you need a stronger signal. The way the coil is wired, the signal wire closes the circuit to ground causing the coil to fire. This shows as a pulse on the voltage wire as well and most components can see that on either one.ShanMan14 said:lol, I about ready to do that! I'm wondering now, if it even matters which of the wires to use? I'm not going to redo it since it's working now, though.
