www.cruiserlift.com/id43.html :dthumb:
Ohhhh yeah $100.00 more for this one!! and I like this one better. i will continue to use my hill and or ramp for a long time :lol:Gas Man said:
Gas, yours only has 2500LB winchGas Man said:
I wonder what the winch LB is on this one...it will get the job done! :lol:jetskifast said:Gas, yours only has 2500LB winch![]()
Winch could also be used for other purposesGSXR750DJ said:True...however..a HD Ultra Classic only weights Dry Weight 788.0 lbs Running Order Weight 819.0 lbs. And a 2005 Valkyrie Rune Dry Weight 811.0 pounds and a 2005 VTX1800 Dry Weight 734 pounds. So I am going to guess that the eatra 500lb ability isn't going to matter anyways seeing how a crusier doesn't come close to the 2500lb weight. :lol:
Using snatch block will double winch pulling powerGas Man said:I've had my and others trucks stuck and this wouldn't work... you need ALOT more pull!!! I don't neither of them would work... heck my current truck weights like 6K!
Bet that 10 K winch mounted up front, is going to pull motorcycle into back of truck :lol:Gas Man said:Did he just say snatch? :screwy: :lol:
And having a 10 ton winch on the front brush gaurd will do the trick as well! I got a idea.... why don't you get one for your vette and leave the 4x4'in to us big boys!:lol:
Maybe you should reread my postGas Man said:Hey I'm just crackin at ya... I'm all over being stuck in the middle of no-where with only a winch to get out... pulleys are great and really help. I currently drive 4 4x4's.... and have owned and in been in many other people's...so don't talk to me like I'm some punk kid... THANK YOU...and please drive thru!
What I don't get is why you are trying to sell a MC lift with the idea of using it as a winch for 4x4'ing? It's not designed for that nor would I use it for that. Is it going to to be mounted to handle that type of pull? Just isn't worth it in my opinion. If you're are going to MC lift your bike in the back with it ok. If you are trying to use it in your 4x4 exploits...then get the right gear! But maybe that is coming from a guy that don't know anything...![]()
