1 - 17 of 17 Posts
anyone ever reversed their gear shift so shifting is opposite? I rode a trackbike once with this setup. I was very hard to get used to.
I'm thinking about setting this up on my streetbike just to make riding abit more exciting.
Reverse shifting is referred to as GP shift. This is used by racers mostly to make an upshift quicker. If your racing or doing trackdays I would try GP shift on the street for a while to get used to it. I've heard alot of people talk about accidently catching an up shift entering a corner and running straight off the track.
Right now you have to turn the handlebars right to turn left, and you want to make it so you shift down to shift up? I've had my foot under the shift lever after making an up shift and made a hard left. The sole of my boot was scraped along the ground and kicked back. If the shift pattern was reversed, you wouldn't be able to make a down shift.
I use to do all my sport bikes GP style. I'm not sure why I quit. If your going to do it for the track bike. You defiantly need to do your street bikes as well. Or convert the street bike long before taking it to the track.You don't want the confusion of forgetting which bike your on and making a wrong shift. It could be deadly.
Not many people downshift in the middle of a turn at full lean. Try to get all that stuff out of the way before you enteer the turn. Plus the pros have rearsets that are adjustable and brought to the highest point for more clearance.
:iagree: with Jeeps and NW... do it to all or none at all. I know that Twisty tried it for a bit and who knows how that ended up. While I agree there are lots of reasons not to do it... there is one reason and that is for better accelleration.
DLITALIEN is right when he says not too many people downshift in the middle of a corner. All your downshifting should be done in the braking area before you tip in. If you have a slipper clutch, you won't get the big rear end step-outs if you shift down too many, but if you don't have one, and you downshift a gear too much, your back wheel will step out. The further you are leaned at the time, the more luck it will take you to remain upright. (trust me on this!!) (caveat.... good technique, blipping the throttle on your downshifts will minimise/negate this situation!)
The race shift pattern (i.e. upside down, GP style) is used in racing to allow the rider to upshift whilst leaned over to the left without having to force his/her foot under the lever. It also helps you to upshift while leaned over to the right, in that you don't need to reach as far with your foot. It's obviously less important for the street, but in a race, if you can do something a tenth of a second quicker, you've only got to do it ten times to gain you a second a lap.
I've changed my street bike ('01 GSXR1000) to a race pattern, so that I could get used to it, after a lifetime of riding "conventional" bikes. I have found that the two advantages I listed above are really worthwhile on the track, and I can't find any valid reason why the "conventional" pattern is an advantage on the street, apart from being easier to explain to newbies(Click up to go up!!). Having said that, there's still plenty of racers who still use a conventional pattern, simply because they're used to it!
P.S. when I changed the Gixxer, I put a dyno label on the speedo that said "race shift" so I wouldn't forget! It took a lot of concious effort to ride before it became instinctive, and I tortured my poor bike a few times in the process. The only way it makes riding more exciting is when you screw up!!
:cheers:
I converted to reverse shift when I got my Ducati and now prefer reverse shift to regular shift. I ride both street & track. I'm purchasing a new bike in the next couple weeks and will be converting it to reverse shift too.
I rode a press bike at Buttonwillow Raceway for a track day a couple months ago that had regular shift and did have a couple mis-shifts but for the most part, I remembered that it was opposite.
What kind of bike are you getting?
1 - 17 of 17 Posts
