Here's a link showing how it's done on a CBR http://forums.cbrworld.net/forums/85183/ShowPost.aspx. Looks very similar to your Kawi. The last picture shows how to adjust the manual CCT.snadamo said:
Here's a link showing how it's done on a CBR http://forums.cbrworld.net/forums/85183/ShowPost.aspx. Looks very similar to your Kawi. The last picture shows how to adjust the manual CCT.snadamo said:I would have no problem buying the manual one and installing it. Its the setup part that scares me. What If i put too much or to little tension on the chain? etc etc.
:readng:No Worries said:Here's a link showing how it's done on a CBR http://forums.cbrworld.net/forums/85183/ShowPost.aspx. Looks very similar to your Kawi. The last picture shows how to adjust the manual CCT.
That who sentance is a great idea when ever you are going to expose them! But I love the term little monsters!!bumblebee said:And remember to Cover your intakes with towel or cloth so little monsters don't get down into your cylinders!!
:iagree: Dirt, sand, metal chips, screws, clamps. Any number of things can fall in.Gas Man said:That who sentance is a great idea when ever you are going to expose them! But I love the term little monsters!!
:iagree: If you know there is a problem, why take a chance of making it worse?bumblebee said:This is where you should be very careful...if it is just starting to make the clicking noise, you can ride it some, just don't be rockin the Tach up and down...as it progresses, the sound goes from the clicking to a "BB's shaking in a beer can" sound that will come and go...eventually, in the 4k and up to about 6K range, it sounds like thin sheet metal vibrating, or someone shaking a thin piece of sheet metal, and this sound doesn't go away.
Worse case...you stretch your cam chain and have to replace it OR...it jumps a tooth or breaks a tooth and you are replacing chain and gears...
jeeps84 said::iagree: If you know there is a problem, why take a chance of making it worse?
Other wise enjoy and don't torture it till you get'er fixed.
snadamo said:man you guys are impaitent!!! :lol:
Okay so I just got home. The vibrating I was talking about at 9k, not as bad as I thought originally, and the legs get tingly but barely. My mind must have been more concentrated on the road, and that just startled me. This only occurs at 9k. You go over, its stops. I guess its that certain RPM that sets off something. Usually the bike vibrates a little when you get around that RPM range a little, (is that normal?) So I really dont know whats up with that.Mines doing the same thing. Mine vibtates my right peg at around 6K RPM's. So is this bad or what? It's not something it use to do when I bought it either.
That kind'of make sense.Gas Man said:I think it much like at my work. If you don't know you are ok and don't have to do anything about it. Once you know you're screwed and must fix it and adjust your daily activities to ensure no further damage.
My old CBR uses the ignition as a rev limiter. Redline is 10,500. Above that, cylinders 2 and 3 are cut off while 1 and 4 are retarded. Above 11,600, the whole ignition shuts down. I've never tested mine above 10,500 (except for a few missed shifts between 1st and 2nd), but I wonder if the spark unit or computer in your ignition is cutting out the same way.snadamo said::..I was at a red light. Once it turned green I monitored my RPM and at 7-9k, it started that rattling again, bad. Anything below that RPM is fine and dandy.
Iv heard of batteries and charging system felling. Thos creating the same thing. It very uncommon for the spark unit or computer to go bad.No Worries said:My old CBR uses the ignition as a rev limiter. Redline is 10,500. Above that, cylinders 2 and 3 are cut off while 1 and 4 are retarded. Above 11,600, the whole ignition shuts down. I've never tested mine above 10,500 (except for a few missed shifts between 1st and 2nd), but I wonder if the spark unit or computer in your ignition is cutting out the same way.
The spark unit is probably hundreds of dollars, but you could test the timing at 7-9k with a timing light in your garage.
:iagree: :withstupijeeps84 said:Iv heard of batteries and charging system felling. Thos creating the same thing. It very uncommon for the spark unit or computer to go bad.
