I bought a 94 gsxr750 a couple of weeks ago I have noticed that the turn signals do not work properly otherwise they do not flash when you turn the turn signal on they are solid there is no flashing. I did put new turn signals on the bike because they did not have any to begin with. I followed the wiring diagram so I know that these are the correct wires left side black(positive) Black w/ white tracer (neg) Right side Light green (positve) Black w/ white tracer (neg). I did put a new turn signal relay in I thought it was the problem.
I hope someone can help me out. Thanks flipmo
I thought that I would let you guys in on the turn signal update so you'll don't have to talk about LED oil. I didn't have nothing to do the other night so I went out to the shop and tinkled around on the bike in the process I pulled up the wiring harness layout on the pc and followed the wires like I did the many times and it led me to the turn signal relay again. So like before I knew this was a new relay and didn't worry about it. Again I checked all grounds and all wires like I have did many times before so this took me back to the relay were I removed it from the plug. I put a test light in the plug and I had power so I got an Idea. The relay acts like a flasher so lets hook a flasher up to it and see what happens. So I made some home made connections for the plug, hooked it up and BLINK BLINK they worked. The new turn signal relay doesn't work it must be a dud so I will be returning it to the delership tomorrow. Just wanted to let you guys know were I was with this.Thanks for all the help and all the smart ass comments. Flipmo
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Two Wheel Forums
A forum community dedicated to Motorcycle and Sportbike owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
