Watter wetter is not meant to be in place of antifreese/coolant
What water wetter does is break down the adhesion of watter, u know how water drops are drops... the watter moecules adhere to each other.. watter wetter stops that from happening, making it so the water at the edge of the engine moves with the rest the water instead of it basically being a water jacket at the edge of the metal that doesnt move and the inside of the line moving.... So if all of it moves it transfers heat better.
It increases heat dispersion, so sitting at a stop itll still get hot, move and itll cool it FASTER not cool more.
Not sure if engine ice does the same or not.
Track u cant run coolant and wetter isnt coolant, and doesnt raise boiling point or raise freezing point. It is not a substitute to antifreeze... its a additive.
