Pickle, have you tuned your suspension? You may not need springs. Have you set the bikes sag? For the front, with you on the bike, it should be between 1.25-1.5 inches. Set the sag using preload adjustments or use cut PVC tubing spacers. After setting the sag and you still have too much front-end dive, then you can get stiffer springs or add extra fork oil.pickle.of.doom said:
